michael breen
#1 Posted : Monday, January 3, 2011 8:20:05 AM(UTC)
michael breen
how to replace pulley wheel #AP4048267
Joe / APP Team
#2 Posted : Tuesday, January 4, 2011 9:12:56 AM(UTC)
Joe / APP Team
Michael,
It appears you're replacing the idler pulley on the washing machine drive system.
Here are excerpts from the general service manual, to get you through the repair.
Once you get to the pulley/shaft assembly, it's pretty much self explanatory.
Good Luck,
Motor Disassembly
1. Remove nuts, steel washers, spacers and rubber
mounts securing motor to mounting bracket
2. Lift motor off mounting bracket and remove
remaining rubber mounts and steel washers from
motor mounting studs.
NOTE: When installing motor on mounting bracket,
position motor with switch facing toward left side
of mounting bracket.
NOTE: When assembling motor to motor bracket, it is
extremely important to make sure the motor is
centered on isolator pads and all fasteners are
evenly torqued.
Idler Lever and Pulley
1. Remove motor, see “Motor and Mounting Bracket”
procedure
NOTE: Lay motor on its side. Observe belt
configuration around rear pump leg. Belt
MUST
encircle rear pump leg when reassembling.
2. Remove nut, washer, and bolt securing idler lever
and pulley to motor mounting bracket.
3. Apply a light film of No. 03637P Lubricant to area of
idler lever that makes contact with motor mounting
bracket
NOTE: DO NOT OVER LUBRICATE! Excess lubricant
can be thrown into pivot dome area during
normal washer operation. Any lubricant on the
pivot dome, base or friction ring will affect
washer operation.
4. Reverse procedure to reassemble
