how to replace pulley wheel #AP4048267
Originally Posted by: michael breen how to replace pulley wheel #AP4048267 Michael, It appears you're replacing the idler pulley on the washing machine drive system. Here are excerpts from the general service manual, to get you through the repair. Once you get to the pulley/shaft assembly, it's pretty much self explanatory. Good Luck, :) :) :) Motor Disassembly
1. Remove nuts, steel washers, spacers and rubber mounts securing motor to mounting bracket
2. Lift motor off mounting bracket and remove remaining rubber mounts and steel washers from motor mounting studs.
NOTE: When installing motor on mounting bracket, position motor with switch facing toward left side of mounting bracket.
NOTE: When assembling motor to motor bracket, it is extremely important to make sure the motor is centered on isolator pads and all fasteners are evenly torqued.
Idler Lever and Pulley
1. Remove motor, see “Motor and Mounting Bracket” procedure
NOTE: Lay motor on its side. Observe belt configuration around rear pump leg. Belt MUST
encircle rear pump leg when reassembling. 2. Remove nut, washer, and bolt securing idler lever and pulley to motor mounting bracket. 3. Apply a light film of No. 03637P Lubricant to area of idler lever that makes contact with motor mounting bracket
NOTE: DO NOT OVER LUBRICATE! Excess lubricant can be thrown into pivot dome area during normal washer operation. Any lubricant on the pivot dome, base or friction ring will affect washer operation. 4. Reverse procedure to reassemble
