yaverhart
#1 Posted : 16 years ago
yaverhart
My disposal is grinding the food, however water is building up in the sink and not sending the food through. The food is being chopped up but everything comes back up the sink.:confused:
Please help!
v2k04
#2 Posted : 16 years ago
v2k04
The pipes are plugged take it apart at the P-trap otherwise good ol draino or a plumber
Garbage disposal not working (Garbage Disposer Repair)
by Guest 4 years ago
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 9 years ago
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 11 years ago
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 12 years ago
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 12 years ago
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 13 years ago
by jakester3 13 years ago
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 13 years ago
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 13 years ago
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 13 years ago
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 13 years ago
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 14 years ago
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 14 years ago
garbage disposals (Garbage Disposer Repair)
by shelterpup 14 years ago
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 15 years ago
