AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Admiral washer stops just before rinse, makes loud screaming noise
Howdy! My washer managed to get all the way through soaping the clothing, and drained the water just before going into the rinse cycle, but then began making a very loud, high-pitched noise. It isn't filling up with water at all, nor is it moving (spinning etc) in any way. What can I do to fix this? Thank you very much for any help! :)
Sounds like a worn belt, or a good belt trying to turn against a locked up brake. Remove the belt and see if you can rotate the pulley in both directions by hand. In one direction, you'll operate the agitator; the opposite direction separates the brake and allows spin. If the brake doesn't release, you need to replace the brake rotor a nd stator; the thrust baring, and the belt. Not easy.
Washer Repair
