fharris5
#1 Posted : Monday, November 24, 2008 10:31:16 AM(UTC)
fharris5
Howdy! My washer managed to get all the way through soaping the clothing, and drained the water just before going into the rinse cycle, but then began making a very loud, high-pitched noise. It isn't filling up with water at all, nor is it moving (spinning etc) in any way. What can I do to fix this? Thank you very much for any help! :)
magician59
#2 Posted : Monday, November 24, 2008 1:03:04 PM(UTC)
magician59
Sounds like a worn belt, or a good belt trying to turn against a locked up brake.
Remove the belt and see if you can rotate the pulley in both directions by hand. In one direction, you'll operate the agitator; the opposite direction separates the brake and allows spin. If the brake doesn't release, you need to replace the brake rotor a nd stator; the thrust baring, and the belt. Not easy.
