mpf
#1 Posted : Tuesday, December 28, 2010 5:15:59 AM(UTC)
mpf
I was wondering if anyone could help diagose the following problems:
Machine powers on. All lights on circuit board light up appropriately. Wash cycle starts to fill at full volume, stops abruptly (without being complete), drum starts rotating, water starts cycling from side fill spout, and just continues to do this without advancing to wash or filling. I can manually skip to the wash cycle and the cycles for washing will advance as normal. Upon reaching the rinse cycle, the water barely trickles in, stops, drum spins and spins without filling, etc. Will not spin properly via the rinse cycle but will spin properly if advance to spin cycle manually. Thank you.
RODDIE COOK
#2 Posted : Friday, January 7, 2011 5:45:56 AM(UTC)
RODDIE COOK
first check the resistance of the pump motor underneath at the right front of the tub the reading should be 7.1 ohms if its .3 ohms thats 0.3 less or more replace the motor. the motor is probbably running very hot, by the time it gets to drain its just gonna shut down.
Guest
#3 Posted : Sunday, December 12, 2021 7:52:26 AM(UTC)
Guest
Rank: Guest
Groups:
United States
My fisher paykel wash smart top loading washer Model #WA4127G1 just started banging loudly in the spin cycles (slow, med. fast ) ! We have adjusted the load evenly, checked water level, machine is balanced and stable ! What can be doing this? Wife is getting upset ! Anyone please help. Their website sucks, No help at all with live chat (Patience) . HELP !!!!!!
Edited by user Friday, December 17, 2021 7:52:13 AM(UTC)  | Reason: need help now !
Guest
#4 Posted : Wednesday, December 15, 2021 8:46:28 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Is it expensive to have a repair man come and look at our Fisher Paykel washer ? Where do I find a good, honest repair man ? We tried to diagnose the machine that keeps on banging in all cycles with an even load, water level, machine level too ! All I could do is unscrew the top control panel. There are no more screws or clips or any other access points visible. How do they get the back and top off of thes things ? ANYONE HAVE THIS PROBLEM ? HELLLLLLPP !
Edited by user Friday, December 17, 2021 7:54:39 AM(UTC)  | Reason: need help now !!!!
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
control agitation in Fisher Paykel washer? (Washer Repair)
by akohls1979 1/28/2022 11:25:32 AM(UTC)
Fisher Paykel DishDrawer DD24 issues (Stuck at 48 minutes and leak) (Dishwasher Repair)
by Mr. Roarke 1/1/2022 4:46:46 PM(UTC)
Fisher Paykel Top Loading Washer (Dishwasher Repair)
by Guest 12/13/2021 6:47:47 AM(UTC)
Fisher Paykel HAndle Cover (Dishwasher Repair)
by Guest 10/23/2021 9:45:12 AM(UTC)
Fisher Paykel Gas Range - Issues with broil burner (Oven Repair (including Ranges and Cooktops))
by extrafu 7/23/2021 6:44:10 AM(UTC)
Fisher Paykel Drain Pump Defect? (Washer Repair)
by windsailor 6/17/2019 12:06:24 PM(UTC)
Fisher Paykel been overflowing now code 130 and stuck (Washer Repair)
by Gilligan8 5/27/2019 8:45:57 PM(UTC)
Fisher Paykel drawer stops with 35-39 minutes left to run. (Dishwasher Repair)
by bobheist 7/7/2015 9:14:39 PM(UTC)
Fisher Paykel not drying (Dryer Repair)
by JanLun71 6/17/2014 7:04:23 PM(UTC)
fisher paykel double oven top oven and broiler elements not working (Oven Repair (including Ranges and Cooktops))
by milo77 11/15/2013 9:17:53 AM(UTC)
Fisher Paykel dryer troubleshooting (Dryer Repair)
by Coopercat2 8/29/2012 6:38:41 AM(UTC)
Fisher Paykel Gas Dryer DGGX1US--No heat (Dryer Repair)
by SEC 12/31/2011 11:22:24 PM(UTC)
It's a gun slinging Fisher Paykel... (Washer Repair)
by dirtwheels 10/30/2011 1:23:24 PM(UTC)
replace bearings Fisher Paykel (Washer Repair)
by rockbr 10/10/2011 1:45:15 PM(UTC)
