maytag direct drive washer it will agitate but want spin
Originally Posted by: rob-o maytag direct drive washer it will agitate but want spin Rob, You supplied a wrong model number(it's a microwave) But, I was able to understand, and found the correct number(MTW5700TQ), I take for granted the motor does run in the spin cycle, since the washer does agitate ? Every thing else works and there are no strange noises ? I'm making a guess here, but you most likely have a problem in the Clutch assembly. Part number: AP3094537
With a bit more information we can be more accurate, but here is an excerpt from our repair forum, to help you diagnose and determine what else could be wrong, and access and repair to the clutch assembly, if needed. http://forum.appliancepartspros...-washer-brake-shoes.htmlIf the motor does not run in the spin cycle, You may also have a bad lid switch, if the switch circuit is bad, it will allow the machine to fill and agitate, but won't let it spin, Part number: AP3180933
Good Luck, :) :) :)
