tripp67
#1 Posted : Monday, December 27, 2010 6:13:50 AM(UTC)
tripp67
it takes 2 cycles to dry cloths. what can i check?
Joe / APP Team
#2 Posted : Monday, December 27, 2010 6:39:22 AM(UTC)
Joe / APP Team
Tripp,
Try this first,
Disconnect the vent from the dryer and dry a load of wash, see if there is an improvement in the time required.
If there is, you'd need to check and clean the exhaust venting, from the dryer to the vent hood (outside).
If there is no improvement, we'll have to get into the circuits and components of the heat cycle,you'll need to get your hands on a multi meter to do the tests.
Part number: AP3873826
Please let us know what you find,
Thanks,
tripp67
#3 Posted : Monday, December 27, 2010 7:57:43 AM(UTC)
tripp67
thanks for answering. I checked the vent and its blowing pretty good out of the back of the dryer. I did feel as if the air was warm but not very hot.
tripp67
#4 Posted : Monday, December 27, 2010 8:02:31 AM(UTC)
tripp67
Originally Posted by: Joe / APP Team Go to Quoted Post
Tripp,
Try this first,
Thanks,
I believe i have good air flow. its warm but not very hot. I also have a voltmeter. what should i do first?
Joe / APP Team
#5 Posted : Monday, December 27, 2010 12:41:33 PM(UTC)
Joe / APP Team
Tripp,
It's great that you have a meter, you'll find it a lot easier and less expensive in the long run.
But,
First, get us a model number, so we can direct you properly, efficiently , accurately.
Thanks,
Admiral electric dryer works 5seconds, stops (Dryer Repair)
by ddrepairdog 7/24/2016 1:17:38 PM(UTC)
Admiral electric dryer turns on some selections but no heat (Dryer Repair)
by Captain Offshore 10/14/2014 11:15:25 AM(UTC)
Admiral Electric Dryer (Dryer Repair)
by BigRedOne 6/13/2014 12:55:08 PM(UTC)
by lorigslater 1/16/2011 2:55:50 PM(UTC)
by Austin3193 12/18/2010 10:40:18 AM(UTC)
Admiral electric dryer won't run (Dryer Repair)
by nhseacoast 3/11/2010 5:51:03 PM(UTC)
Replacement of Blower Wheel on a Admiral Electric Dryer (Dryer Repair)
by Davo67 5/12/2009 12:40:51 PM(UTC)
by Shawn M. 2/11/2009 2:26:28 PM(UTC)
