Hello I have an Amana Dryer that is now 5 years old, it stopped drying clothes just blowing cold air recently, so I ordered some parts after searching the forum here, and replaced the Thermostat, Heater Element and Thermal Fuse. The dryer once reassembled jumped back to life and was working like brand new, after about four or five loads, we are back to square one, it does not heat and dry any of the clothes, any suggestions? Please Help. Thanks.
Yes, the thermal fuse, that is mounted on the element, probably burn't out. Alot of times that happens because the vent is clogged to the outside. Or the the blower housing is clogged up on the inside. Tom ApplianceEducator.com
