We want to replace our fuse box above our dryer (it's a sub panel). The round screw in fuses are constantly blowing. We have a new fuse box and circuit breaker switch to replace it. The question is how do we wire it?
First : Disconnect the sub-panel at the main panel.
Second : After verifying that the power is off (use a good meter) remove the wires from L1, L2, and N (Supply from Main)
Third : Remove wires from T1, T2, and N (Lines going to Dryer)
Fourth : Remove "Edison Base" sub panel
Fifth : Install new breaker panel
Sixth : Connect L1, L2, N (Supply from Main)
Seventh : Connect wires( from Dryer) to breaker. This would be a dual pole. L1 to top half of breaker, L2 to bottom half of breaker. N to neutral buss bar (long silver bar).
Eighth : With breaker in off posistion, snap-in to panel.
Ninth : Turn main breaker back on
Tenth : Turn on breaker in sub-panel.
Dry your wash. :)
thank you for your quick response:)
our wires are red, white, black and what appears to be 1 copper wire which would be l1,l2,n??
also, it had 2 fuses before and now will have 2 breakers, does that change things/wiring? thanks again
:) Black= L1, Red = L2, White= Neutral Bare Copper to Green ground screw.
Originally Posted by: sakleist2  also, it had 2 fuses before and now will have 2 breakers, does that change things/wiring? thanks again Should be a dual breaker (two connected with a bar). L1 = top screw, L2 bottom screw. :)
