triciah720
#1 Posted : Sunday, November 23, 2008 7:41:14 AM(UTC)
triciah720
I have an older Kenmore side by side refrigerator. A few months ago, someone went to get water from the door and it wouldn't shut off. After about 30 minutes of standing there, going from the frig to the sink, it finally shut off. I have warned friends Not to try and get water, but yesterday, someone was here working on my kitchen and he went to get some water. It just kept running and running. Finally I turned off the water at the valve. Is there some kind of switch that I can turn off to keep it from dispensing water, but still get water to it to make ice?
#2 Posted : Sunday, November 23, 2008 4:05:03 PM(UTC)
Sounds like the problem is a stuck water inlet valve or a stuck switch in the water dispenser . In order to provide more accurate advise we need the complete model number of the refrigerator. This link can help you to locate it.
triciah720
#3 Posted : Monday, November 24, 2008 8:06:41 AM(UTC)
triciah720
Gene, I finally found the model number. It's 363.50222000. The SN is 03026273. I appreciate any advice you can give me. Thanks!
#4 Posted : Thursday, November 27, 2008 11:04:44 PM(UTC)
Check the dispenser switch (#72 on the break down diagram) and the water inlet valve (#800 on the break down diagram).
In order to stop water from the dispenser while keep it for the ice maker, you have to remove the wires from the drinking water solenoid on the water valve.
triciah720
#5 Posted : Sunday, November 30, 2008 12:45:32 PM(UTC)
triciah720
Where are the wires to remove from the drinking water solenoid?
#6 Posted : Monday, December 1, 2008 10:17:22 AM(UTC)
There is a 5/16" plastic tube connected to this solenoid.
Guest (4)
