Wilber1
#1 Posted : Monday, December 20, 2010 7:57:51 AM(UTC)
Wilber1
The range has a red light that has come on in the front upper left, and at the same time the two left burners no longer work- no gas and no spark. The right two burners still work fine. I cannot figure out how to get into the left section of the oven, under the burners. The right side is easy, it can be accessed just by removing the grill. I don't know if I even to get into that area, however. Any idea what is going on? Thanks
Servicer
#2 Posted : Saturday, February 19, 2011 4:55:14 PM(UTC)
Servicer
The simmer control module has gone bad. It would be best to order the kit which gives you a simmer control as well as both potentiometers; part number 497234.
