The range has a red light that has come on in the front upper left, and at the same time the two left burners no longer work- no gas and no spark. The right two burners still work fine. I cannot figure out how to get into the left section of the oven, under the burners. The right side is easy, it can be accessed just by removing the grill. I don't know if I even to get into that area, however. Any idea what is going on? Thanks
The simmer control module has gone bad. It would be best to order the kit which gives you a simmer control as well as both potentiometers; part number 497234.
