In rinse cycle; starts and stops slowly then changes direction 15 to 20 rpm. In spi/extract it turns slowly with bursts of high speed(few seconds). Could this be a control or a motor problem?
Most commonly the motor controller. On this model they made some changes, if it has the original motor & motor controller in it it would probalby need both of those and the conversion kit. Here's the breakdown Model MAH4000AWWNat
Maytag replaced electronic control board and door latch assy and Motor WAX p/n 22002119 and Motor conversion kit p/n 12002039. Does this help? in 2004.
ok, then you will just need to check the motor control board and motor.
Nat
