Freezer coil iced over two months ago. Replaced defrost heater only. Wire to one side of heater showed overheating marks on the insulator but the solderless connector looked ok. Refrigerator worked until now, icing over again. Checked continuity of heater element and it's OK. Fan is working so I defrosted and started unit. Cools for awhile and then starts to ice over again. Should I have replaced the thermostat defrost device and/or the sensor temp ff.. Would the board be at fault. Temperature in freezer section stayed around 10 to 20 degrees and the refreigerator section around 35 to 40degrees with both stats set at #3. Could the board be at faullt. Thank you for your help!.
Originally Posted by: bksbjmds8  Freezer coil iced over two months ago. Replaced defrost heater only. Wire to one side of heater showed overheating marks on the insulator but the solderless connector looked ok. Refrigerator worked until now, icing over again. Checked continuity of heater element and it's OK. Fan is working so I defrosted and started unit. Cools for awhile and then starts to ice over again. Should I have replaced the thermostat defrost device and/or the sensor temp ff.. Would the board be at fault. Temperature in freezer section stayed around 10 to 20 degrees and the refreigerator section around 35 to 40degrees with both stats set at #3. Could the board be at faullt. Thank you for your help!. Could a faulty circuit board cause icing over of the cooling coil in a side by side GE refrigerator
Rank: Administration
Groups: Administrators
Dear bksbjmds8 Its possible to be the board on this because this model has the adaptive defrost built into the main control board. They can be somewhat difficult to diagnose so you may consider trying the sensors or the defrost thermostat first.
