filthmaster
#1 Posted : Thursday, December 16, 2010 5:50:50 PM(UTC)
filthmaster
i have a dryer that does not heat up have checked igniter and flame sensor both check out whats next?:confused:
Joe / APP Team
#2 Posted : Friday, December 17, 2010 1:39:23 PM(UTC)
Joe / APP Team
Filthmaster,
Apparently this is a gas dryer,
Does the igniter glow and does it cycle off with no flame ?
(if so, suspect you have a bad set of gas valve coils).
If nothing occurs, you'll need to circuit check all your thermostats, they all should be a "closed" circuit at room temperature.
Also check for any loose or broken wires.
We could be more accurate with a model and serial number for the dryer.
Question about start relay replacement, any help? (Refrigerator & Freezer Repair)
by mysterycereal 10/7/2009 10:25:39 PM(UTC)
