i have a dryer that does not heat up have checked igniter and flame sensor both check out whats next?:confused:
Originally Posted by: filthmaster  i have a dryer that does not heat up have checked igniter and flame sensor both check out whats next?:confused: Filthmaster, Apparently this is a gas dryer, Does the igniter glow and does it cycle off with no flame ? (if so, suspect you have a bad set of gas valve coils). If nothing occurs, you'll need to circuit check all your thermostats, they all should be a "closed" circuit at room temperature. Also check for any loose or broken wires. We could be more accurate with a model and serial number for the dryer. :) :) :)
