Ice maker dumps ice only two or three times each day. Ice maker water fill appears to be OK. Freezer temp. reads zero on a refrigeration thermometer. Cubes freeze solid in a short period of time but, the eject cycle does not take place until several hours later. Please help me determine what component(s) might be causing this and how I can test to confirm.
If your feeling BRAVE!!!LOL!!! Its most likely the THERMOSTAT in the icemaker, Its not bad to change,once you find it!!!!:D
Here some help with troubleshooting v2k04 attached the following image(s):
