Ron Manuel
#1 Posted : 16 years ago
Ron Manuel
Ice maker dumps ice only two or three times each day.
Ice maker water fill appears to be OK. Freezer temp. reads zero on a refrigeration thermometer. Cubes freeze solid in a short period of time but, the eject cycle does not take place until several hours later.
Please help me determine what component(s) might be causing this and how I can test to confirm.
Drags1998
#2 Posted : 16 years ago
Drags1998
If your feeling BRAVE!!!LOL!!! Its most likely the THERMOSTAT in the icemaker, Its not bad to change,once you find it!!!!:D
v2k04
#3 Posted : 16 years ago
v2k04
Here some help with troubleshooting
v2k04 attached the following image(s):
