Carlos29
#1 Posted : Wednesday, November 19, 2008 12:23:37 PM(UTC)
Carlos29
:confused: My Whirlpool Electric Dryer wont dry the clothes and the timer doesnt work, wut can i do? Model #:LER4634PQO, if you can help pliz do. Thank You.
libertyappl
#2 Posted : Wednesday, November 19, 2008 12:53:56 PM(UTC)
libertyappl
Does the dryer turn on at all?
Nat
Drags1998
#3 Posted : Wednesday, November 19, 2008 1:34:28 PM(UTC)
Drags1998
Try the timer on the "TIMED DRY" cycle, Does it Move? If it does, Timer is all Thermostats, I'll bet on the thermostat on the TOP of the heater!!!!:)
SublimeMasterJW
#4 Posted : Wednesday, November 19, 2008 1:56:21 PM(UTC)
SublimeMasterJW
It is probably the heat element. Take the back off the dryer. Unplug your dryer remove the heater and look for breaks. All you gotta do is remove 2 screws from the heater and unplug 2 wires.
SublimeMasterJW attached the following image(s):
