:confused: My Whirlpool Electric Dryer wont dry the clothes and the timer doesnt work, wut can i do? Model #:LER4634PQO, if you can help pliz do. Thank You.
Does the dryer turn on at all?
Nat
Try the timer on the "TIMED DRY" cycle, Does it Move? If it does, Timer is all Thermostats, I'll bet on the thermostat on the TOP of the heater!!!!:)
It is probably the heat element. Take the back off the dryer. Unplug your dryer remove the heater and look for breaks. All you gotta do is remove 2 screws from the heater and unplug 2 wires.  SublimeMasterJW attached the following image(s):
