I have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct? would the temp probe go back and show no code? I have the ES 100/105 EOC. Thanks
A model number may help others help you Model Number Locator[COLOR="Blue"]I have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct?[/COLOR] I cannot say as you did not specify where the meter leads were. Many units always have 120 volts on them when measured to Neutral/ground. The element requires the full 240 volts. Also the Neutral/ground is not part of the element heating current path. [COLOR="Blue"]would the temp probe go back and show no code? I have the ES 100/105 EOC.[/COLOR] I cannot say. Voltage Check Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: wingnut9999  I have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct? would the temp probe go back and show no code? I have the ES 100/105 EOC. Thanks Model 790.95032503
Originally Posted by: denman  A model number may help others help you Model Number LocatorI have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct? I cannot say as you did not specify where the meter leads were. Many units always have 120 volts on them when measured to Neutral/ground. The element requires the full 240 volts. Also the Neutral/ground is not part of the element heating current path. would the temp probe go back and show no code? I have the ES 100/105 EOC. I cannot say. Voltage Check Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! model 790.95032503
Here is the wiring diagram http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441458en.pdfLooks like a fairly simple unit. It does not sound like the unit is coming ready or giving a false ready signal. If the stove top elements are heating OK and their indicator lights are OK then your power is probably OK. Then all that is left is the control board. Wouldn't hurt to double check power etc. |
I'm having the exact same issue with the exact same model, and am really wanting to narrow down the possibilities as the EOC part is ~$100 from this site. That's approximately 25% of the total cost of the unit, so before I pull the trigger on that part, I really want to be sure. Are there a few simple tests you recommend like the power check etc. that I can do in order to be sure? Thanks for your time.
