wingnut9999
#1 Posted : Sunday, December 12, 2010 8:14:11 AM(UTC)
wingnut9999
I have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct? would the temp probe go back and show no code? I have the ES 100/105 EOC. Thanks
#2 Posted : Sunday, December 12, 2010 12:10:06 PM(UTC)
A model number may help others help you
Model Number Locator
[COLOR="Blue"]I have a Sears Kenmore oven and it does not heat. I put a meter on the bake element and have 116 volts as well as the broil element. I get no error codes. Is testing the voltage correct?[/COLOR]
I cannot say as you did not specify where the meter leads were.
Many units always have 120 volts on them when measured to Neutral/ground.
The element requires the full 240 volts.
Also the Neutral/ground is not part of the element heating current path.
[COLOR="Blue"]would the temp probe go back and show no code? I have the ES 100/105 EOC.[/COLOR]
I cannot say.
Voltage Check
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
wingnut9999
#3 Posted : Sunday, December 12, 2010 4:01:19 PM(UTC)
wingnut9999
Model 790.95032503
wingnut9999
#4 Posted : Sunday, December 12, 2010 4:02:41 PM(UTC)
wingnut9999
I cannot say.
Voltage Check
If OK
If OK
model 790.95032503
#5 Posted : Monday, December 13, 2010 5:39:46 AM(UTC)
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441458en.pdf
Looks like a fairly simple unit.
It does not sound like the unit is coming ready or giving a false ready signal.
If the stove top elements are heating OK and their indicator lights are OK then your power is probably OK.
Then all that is left is the control board.
Wouldn't hurt to double check power etc.
Flooder305
#6 Posted : Thursday, December 30, 2010 8:20:22 PM(UTC)
Flooder305
I'm having the exact same issue with the exact same model, and am really wanting to narrow down the possibilities as the EOC part is ~$100 from this site. That's approximately 25% of the total cost of the unit, so before I pull the trigger on that part, I really want to be sure. Are there a few simple tests you recommend like the power check etc. that I can do in order to be sure? Thanks for your time.
Guest (6)
