welsco
#1 Posted : Tuesday, November 18, 2008 7:20:16 AM(UTC)
welsco
My Dryer lights up but goes out after about a minute. I tested the solenoid coils, one was bad, and replaced the bad one, but still am having the same problem. Could there be some other problem. When dryer first comes on flame is strong and bluish in color.
magician59
#2 Posted : Tuesday, November 18, 2008 8:52:52 AM(UTC)
magician59
Normally, we replace the coils as a set. Does this problem occur in any cycle you select?
welsco
#3 Posted : Tuesday, November 18, 2008 9:49:38 AM(UTC)
welsco
Hi, I just checked both the timed cycles and the more dry less dry. The flame stayed on for about a minute on more/less and about 15 seconds on the timed. thanks
teagen23
#4 Posted : Tuesday, November 18, 2008 3:46:48 PM(UTC)
teagen23
I have the same problem. Admiral dryer. Replaced both coils. Flame comes on then goes out. Then comes on a little later but goes out. Glows for a while.Model # adg7005aww.
icehouse
#5 Posted : Tuesday, November 18, 2008 6:39:35 PM(UTC)
icehouse
Possibly UserPostedImage Flame sensor - Senses flame for heat allowing gas valve to open.
