My Dryer lights up but goes out after about a minute. I tested the solenoid coils, one was bad, and replaced the bad one, but still am having the same problem. Could there be some other problem. When dryer first comes on flame is strong and bluish in color.
Normally, we replace the coils as a set. Does this problem occur in any cycle you select?
Hi, I just checked both the timed cycles and the more dry less dry. The flame stayed on for about a minute on more/less and about 15 seconds on the timed. thanks
I have the same problem. Admiral dryer. Replaced both coils. Flame comes on then goes out. Then comes on a little later but goes out. Glows for a while.Model # adg7005aww.
Possibly Flame sensor - Senses flame for heat allowing gas valve to open.
