Is the heating element bad if the resistance across it measures10 ohms ? The t-stat measures zero.
Originally Posted by: rcillo  Is the heating element bad if the resistance across it measures10 ohms ? The t-stat measures zero. RC, Your element resistance is in range(10 to 30 ohms resistance). Your thermostat is the culprit, it should read infinite resistance(000) or a closed circuit. :) :) :)
