My frig. in not cooling on freezer or refrig.side i hear click noise every few minutes and fan is moving but stop getting cold and ideas on what to check thanks.
Unplug the unit and check the start relay. If you remove it and it rattles replace it.
Nat
The over load a relay kit on this product always go out. Replace it, and you will be done with it. Tom ApplianceEducator.com
