tiggertail@tx.rr.com
#1 Posted : Tuesday, December 7, 2010 6:23:53 AM(UTC)
Dryer timer advances only if set in a certain spot. Clothes take forever to dry. Inside of dryer is very humid heat, not dry heat. We replaced the heating element about a year ago and cleaned out the vent. Is it the timer or something else? Thanks for the help!
magician59
#2 Posted : Tuesday, December 7, 2010 6:48:32 AM(UTC)
magician59
This may seem disconnected: Long dry times are often associated with clogged or restricted ventilation. You say you cleaned out the vent. Is your washer thoroughly spinning the clothes to a damp dry?
#3 Posted : Tuesday, December 7, 2010 7:07:55 AM(UTC)
Sometimes I do have to run the Maytag washer through another spin cycle to get more water out.
magician59
#4 Posted : Tuesday, December 7, 2010 7:33:05 AM(UTC)
magician59
this may be the cause of your long drying sessions. What's the model number on your washer?
