The heating element in my dishwasher doesn't get hot. I've been attempting to check the heating element using a digital multimeter.
On this dishwasher, the heating element leads are held in place by a threaded plastic sleeve. The wiring to the leads runs up through the plastic sleeves and connects to the element leads.
When I unscrew the plastic sleeves, it appears that the electrical wires are soldered to the element leads.
Without removing the wiring, I have placed the mutimeter leads on the heating element leads to check the resistance. The resistance measures about 20 ohms.
I'm hesitant to disconnect the electrical wiring from the heating element leads because I'm not confident that I can reconnect it properly.
Do I really need to disconnect the wires before checking the resistance? Is it possible that the heating element could be bad and I am actually measuring an alternate electrical pathway?
If the heating element is likely still good, what part do I check next, and where do I find that part?
Thanks for the help! Steve
THIS FORUM IS DEAD!!!!!!! |
