janice56@telus.net
#1 Posted : Thursday, December 2, 2010 11:23:46 AM(UTC)
janice56@telus.net
Dishwasher Will Not Drain. Have Checked The Pump Working Fine. Have Checked Hoses They Are Not Plugged Or Kinked. Am Puzzled. Rob.
magician59
#2 Posted : Thursday, December 2, 2010 12:06:33 PM(UTC)
magician59
If it drains into the garbage disposer, check to see if the drain inlet is clogged. If you recently installed a new disposer, make sure the plastic plug has been removed from the inlet.
janice56@telus.net
#3 Posted : Thursday, December 2, 2010 12:56:43 PM(UTC)
janice56@telus.net
thank you for your quick response. we checked that out before we wrote. we think it could be the pump. the pump is running but we wonder if it does not have enough ump to pump the water. we took the hose off the bottom and it will not even pump the water on the floor. also wondering if it could be the timer. thanks
janice56@telus.net
#4 Posted : Thursday, December 2, 2010 12:59:22 PM(UTC)
janice56@telus.net
thank you for your quick response. we checked that out before we wrote the first time. could it be the pump. it is running but maybe does not have enough ump to pump. we took the bottom hose off and it will not pump it on the floor either. but it runs. could it maybe the the timer .
magician59
#5 Posted : Thursday, December 2, 2010 1:19:21 PM(UTC)
magician59
The pump may be clogged. Check it for obstructions or debris.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
