Dishwasher Will Not Drain. Have Checked The Pump Working Fine. Have Checked Hoses They Are Not Plugged Or Kinked. Am Puzzled. Rob.
If it drains into the garbage disposer, check to see if the drain inlet is clogged. If you recently installed a new disposer, make sure the plastic plug has been removed from the inlet.
thank you for your quick response. we checked that out before we wrote. we think it could be the pump. the pump is running but we wonder if it does not have enough ump to pump the water. we took the hose off the bottom and it will not even pump the water on the floor. also wondering if it could be the timer. thanks
thank you for your quick response. we checked that out before we wrote the first time. could it be the pump. it is running but maybe does not have enough ump to pump. we took the bottom hose off and it will not pump it on the floor either. but it runs. could it maybe the the timer .
The pump may be clogged. Check it for obstructions or debris.
