Dryer is dead. Checked the power source and there is a current. Went to replace fuses, but can't find them. Not shown in drawing. Please help.
Lift top of dryer, you will find your thermal fuse on the right side of the heater housing, if bad, order a new one by clicking on your model # above You may need to call appliancepartspros to get part #. Before replacing, make sure your venting is ok, primary cause of fuse failure.
