David Marcet
#1 Posted : Monday, October 1, 2007 11:35:42 AM(UTC)
David Marcet
Dryer is dead. Checked the power source and there is a current. Went to replace fuses, but can't find them. Not shown in drawing. Please help.
#2 Posted : Tuesday, October 2, 2007 3:05:08 AM(UTC)
Lift top of dryer, you will find your thermal fuse on the right side of the heater housing, if bad, order a new one by clicking on your model # above You may need to call appliancepartspros to get part #.
Before replacing, make sure your venting is ok, primary cause of fuse failure.
