snooki
#1 Posted : Wednesday, December 1, 2010 5:11:55 PM(UTC)
snooki
our 3 yr old maytag dryer had been working fine then went to use it a few hours later and it wont turn on. never showed any problems was drying like it should and then went to use it and nothing wont turn on , the light in side works .any ideas as to what i could check on it?
kayakcrzy
#2 Posted : Thursday, December 2, 2010 1:39:08 AM(UTC)
kayakcrzy
Yes it is most likely the thermal fuse. It is mounted to the heater. It is item #6 on the picture of your product, on the heater picture. You could always jump it out hjust to check it and see if it works, but don't run it that way. Tom ApplianceEducator.com
#3 Posted : Thursday, December 2, 2010 3:44:44 AM(UTC)
Here are your parts, includes a wiring diagram
Replacement parts for MAYTAG MDE308DAYW DRYER- ELE | AppliancePartsPros.com
You may want to check the power.
On this unit the light bulb works off of L2 while the motor runs off of L1.
So if you loose the L1 side, it will not start.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
