wendieww
#1 Posted : 14 years ago
wendieww
I replaced the heating element in the bottom oven. When I took the old heating element out, I also took out the wires attached to it. (I didn't realize that they just pulled off!) Anyway, I got everything re-connected (I think) but now the oven will come on but neither the top nor bottom oven will heat up. Is there some kind of reset button?
ApplianceJunk
#2 Posted : 14 years ago
ApplianceJunk
There is no reset button. Why did you replace the element? Are you sure the old element was bad?
You can download a copy of the service manual for the Maytag gemini oven at this URL.
16010107 Maytag Gemini Range Service Manual - ApplianceDigest.com
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 9 years ago
Maytag Gemini Oven wont heat (Oven Repair (including Ranges and Cooktops))
by Stevewk 12 years ago
Maytag Gemini Oven (Oven Repair (including Ranges and Cooktops))
by ekuntz 15 years ago
Maytag Gemini oven is not heating up (Oven Repair (including Ranges and Cooktops))
by Daria 15 years ago
