Kip Harkness
#1 Posted : Monday, October 1, 2007 8:13:10 AM(UTC)
Kip Harkness
The dishwasher appears to be receiving very little water and will not disolve the detergant. I have checked the water valve to the unit and it is ok, what could be wrong with the unit and how do I diagnose?
#2 Posted : Wednesday, October 3, 2007 5:52:22 PM(UTC)
Hi Kip Harkness
If there is nothing wrong with the water shut off valve under the sink then the problem is a bad or clogged water inlet valve in the dishwasher and it has to be replaced.
- The part number for the new water inlet valve AP2039339
Good luck.
