malescat
#1 Posted : Monday, November 29, 2010 9:12:53 AM(UTC)
malescat
My fridge runs too cold on both sides even tho conrols are on lowest (left) settings. I recieved erroneous advice to replace the cold control and the adaptive defrost control board. I replaced both and there's been no change. What now?
#2 Posted : Tuesday, November 30, 2010 2:33:52 AM(UTC)
Replacement parts for MAYTAG MSD2656DEW REF - SXS/I&W | AppliancePartsPros.com
The cold control (Item 3 in Section 2) should have at least fixed the freezer side.
Does the compressor cycle?
What is the temperature in the freezer?
Should be between 0 and 5 degrees F.
malescat
#3 Posted : Tuesday, November 30, 2010 4:42:41 PM(UTC)
malescat
Originally Posted by: denman Go to Quoted Post
Hi, denman. Everything works well except that I must keep the controls way left (#1) in order to maintain nearly 0 deg/nearly freezing. I did notice on the old cold control a faint red mark on the ceramic portion near the connection tab. I switched the red and blue wires when I removed the new adaptive defrost board, just in case it mattered - but I don't expect any change. Carl
