Tammy1977
#1 Posted : Friday, November 26, 2010 9:12:37 AM(UTC)
Tammy1977
I used the dryer yesterday and it was fine, today it won't start. I am not sure what to check first.
#2 Posted : Sunday, November 28, 2010 2:11:45 AM(UTC)
I cannot find any info on the given model number.
Here is info on a PYE2300AYW, includes a wiring diagram
Replacement parts for MAYTAG PYE2300AYW Dryer - Ele | AppliancePartsPros.com
First check power to the unit
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Another way to check if you have the 120 volt side for the motor etc. is to put the unit into timed dry if the timer advances you have that side of the line.
Next would be the thermal fuse (Item 5 in Section 5) (see below) or the door switch or the start switch.
The safest way to check theses is measuring with a meter using resistance (ohms). Since this is done with the unit unplugged you do not have to worry about getting a shock.
Thermal Fuse
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
kayakcrzy
#3 Posted : Sunday, November 28, 2010 5:42:27 AM(UTC)
kayakcrzy
Tammy the first thing you want to check is the breaker. Flip it off and on a few times, then see if the dryer heats. If not, unplug the dryer, and get a putty knife, and slide it under the top on the right side, about 3 inches from the end on the right side, and you will hit a clip, that will release the top on that side. Push in, and pop up the top on that side. Do the same on the other side. Once the top is up, rest it on the back wall. The heating element will be in the back in the middle up top. It will either be the heating element or the thermostat, that is mounted right over the heating element. The element part # is LA -1044, and the thermostat is 53-0771. If the element is bad, the thermostat will come with the element. The parts are cheap!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
