savetheday
#1 Posted : Tuesday, November 11, 2008 3:39:16 AM(UTC)
savetheday
Overnight my fridge stop cooling. The fan is running and when I mover the temp control to zero it turns off. The compressor is very warm to the touch. There is no Ice as it already defrosted. any thoughts?
libertyappl
#2 Posted : Tuesday, November 11, 2008 8:14:43 AM(UTC)
libertyappl
Sounds like the compressor is seized. Unplug the unit let it set for a while(until the compressor cools) then plug it back in and listen for a clicking. Remove the start relay ans shake it, if it rattles then that's your problem. If it's clicking (and no rattle) you probably need to go shopping or call a certified tech for compressor replacement.
Nat
savetheday
#3 Posted : Tuesday, November 11, 2008 8:26:50 AM(UTC)
savetheday
Thank you for your reply. I came home for lunch and plugged it back in and herd a click and then a high pitch sound right after the click followed by a 2nd click then nothing. should I go shopping?
libertyappl
#4 Posted : Wednesday, November 12, 2008 6:49:19 AM(UTC)
libertyappl
Did you check the relay connected to the compressor?
Kenmore.. fan running but not cooling.. (Refrigerator & Freezer Repair)
by ultimix 12/19/2008 7:05:24 AM(UTC)
