foxchase
#1 Posted : Friday, November 19, 2010 11:58:24 AM(UTC)
foxchase
I have a freezer that appears to have a thermostat problem and I'm ready to buy parts to fix but am unsure as to the correct part to buy or if I need more than one part.
Here's the problem:
Using 0 as the lowest setting and 10 as the highest, here's the testing and symptoms:
Set temp control knob to 4, compressor runs, freezer works fine.
As it warms up, the knob needs to be turned up to 5-6 then back down to ~3.5 until I here the "click" of the thermostat that turns compressor on.
If I set it to 10 then I must wait for it to warm-up until it hits the 6-7 threshold. I then have to turn back to 5 to find the "click" to engage the thermostat.
Is this simply a Cold control Part Number: AP3426046
or
do I need to buy the Run capacitor - 12 uf. Part Number: AP2071964
and/or
do I need to buy the Relay Part Number: AP3414961
Thanks!
Joe
#2 Posted : Friday, November 19, 2010 12:37:39 PM(UTC)
What is your problem here, too warm, erratic, etc?
foxchase
#3 Posted : Friday, November 19, 2010 12:40:29 PM(UTC)
foxchase
It requires me (instead of thermostat) to turn the cold setting control knob down and up past the temperature point to activate the compressor.
#4 Posted : Saturday, November 20, 2010 1:48:57 AM(UTC)
I would replace the cold control AP3426046 You could try a non-residue cleaning spray on it, might fix it.
foxchase
#5 Posted : Saturday, November 20, 2010 7:41:32 AM(UTC)
foxchase
It there a mechanical coil that determines the thermostat actuation that makes you recommend spraying it down? And is electro cleaner a good spray solution?
#6 Posted : Saturday, November 20, 2010 7:51:21 AM(UTC)
You spray non-residue cleaning spray in any crack in the cold control housing.
