KenPaul
#1 Posted : Saturday, November 8, 2008 10:02:24 AM(UTC)
KenPaul
So, the dishwasher stopped drying the dishes. This could mean a couple of things, but one thought was a defective heater element. When I pulled the unit out this morning, I found a wire had come off the heater element.
Upon closer inspection, it appeared to have burned :eek: (some melted insulation, some charred plastic). The connector itself was still attached to the element, but the wire was no longer attached.
Even though a disconnected element explains the lack of drying, I'm thinking this indicates something else is wrong. Any ideas or recommendations?
v2k04
#2 Posted : Sunday, November 9, 2008 6:43:50 AM(UTC)
v2k04
ohm out the element to verify its still good put a new terminal on the wire and reattach it to the element if it works your good to go.
