Dark Knight79
#1 Posted : Saturday, November 8, 2008 9:35:12 AM(UTC)
Dark Knight79
Hi got a washer/dryer top load combo that is only 6 years old. It just stopped draining the other day. Did one load. Worked. Next load. Didnt. Replaced the pump motor with a new one and checked the lines for any blockage but they are good. Any ideas? Does the spin cycle good and everything else but will not drain. Driving me nuts! Any help/ideas would be appreciated!
Doug
henk2845
#2 Posted : Tuesday, November 11, 2008 6:46:17 AM(UTC)
henk2845
A dumb question, but have you checked your pump? If the impeller does not turn it will not get rid of the water. It could be caused by a foreign object in the housing, obstructing the movement of the impeller. I had that problem on my washer .
magician59
#3 Posted : Tuesday, November 11, 2008 8:26:36 AM(UTC)
magician59
I have also seen cases where a quarter or similar coin gets into the pump and prevents the discharge flapper to rise enough to let the water drain. It will seem like a clog or restriction during drain, where a trickle of water gets by, then the pump stops after a failed attempt to drain.
Washer wont drain, after motor replacement (Washer Repair)
by rweltz 6/15/2018 4:41:50 AM(UTC)
Whirlpool washer wont drain or spin (Washer Repair)
by nancyelaine 2/15/2017 7:59:14 PM(UTC)
Frigidaire stacked washer wont drain (Washer Repair)
by Davidc67 2/11/2017 2:03:16 PM(UTC)
washer wont drain and trips circuit (Washer Repair)
by cglou 11/29/2016 1:07:14 PM(UTC)
Dishwasher wont drain - had new motor (Dishwasher Repair)
by brady5885 10/31/2015 9:51:05 AM(UTC)
Washer Wont Drain At End of Cycle (Washer Repair)
by mvrk28 8/2/2015 3:24:30 PM(UTC)
by rviets 6/24/2015 2:45:24 AM(UTC)
Roper washer wont drain or spin (Washer Repair)
by tj1217 8/13/2014 6:33:05 AM(UTC)
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
washer wont drain or spin, will agitate only on light cycle (Washer Repair)
by maggie_o 10/21/2013 2:09:20 PM(UTC)
Whirlpool washer wont drain (Washer Repair)
by handyjohn 5/7/2013 8:45:52 AM(UTC)
combo washer wont drain or spin (Washer Repair)
by justair 4/13/2013 9:57:54 PM(UTC)
fridgidare stack washer wont drain (Washer Repair)
by d.stroker 3/6/2013 1:17:26 PM(UTC)
LG washer wont drain (Washer Repair)
by Sunshine56 11/14/2012 6:36:13 AM(UTC)
washer wont drain or spin after replacing balancing ring (Washer Repair)
by mn2az87 10/3/2012 12:59:03 AM(UTC)
