Freezer works fine. Defroster works fine because the coils are always clean. The drain hole is the problem. It always freezes up in 3 to 5 days. Drain is clean and I even put vasiline around the hole to make the water drain easily during defrost. Today someone told me to make sure it was level so I am trying that, it was 1/2 inch off. I can poor water in drain and all water drains through like always. Why is drain hole freezing up?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Where on a crosly fringe where do I por hot water down the drain hose
