Rickey Fritcher
#1 Posted : Thursday, November 18, 2010 9:47:26 AM(UTC)
Rickey Fritcher
Freezer works fine. Defroster works fine because the coils are always clean. The drain hole is the problem. It always freezes up in 3 to 5 days.
Drain is clean and I even put vasiline around the hole to make the water
drain easily during defrost. Today someone told me to make sure it was
level so I am trying that, it was 1/2 inch off. I can poor water in drain and
all water drains through like always. Why is drain hole freezing up?
Guest
#2 Posted : Wednesday, April 3, 2024 1:19:44 PM(UTC)
Guest
Rank: Guest
United States
Where on a crosly fringe where do I por hot water down the drain hose
