bdutil1000
#1 Posted : Thursday, November 18, 2010 8:13:56 AM(UTC)
bdutil1000
My fridge is very loud. The fan makes a loud noise but is not loose. It seems to be sealed, but is some way to lubricate it? Not sure if that would help. Any ideas?
#2 Posted : Thursday, November 18, 2010 8:36:15 AM(UTC)
They have had trouble with the rubber motor grommets on these, I usually add a grommet (a small rubber washer will work) to the mounts to stiffen them up.
bdutil1000
#3 Posted : Thursday, November 18, 2010 8:48:11 AM(UTC)
bdutil1000
Thanks, I'll give that a try.
bdutil1000
#4 Posted : Tuesday, November 30, 2010 10:34:44 AM(UTC)
bdutil1000
Sprayed WD40 on the fan motor without removing the motor. It had no immediate effect, but the next day it was very quiet. Almost 2 weeks later and all is still well and quiet. Huge improvement.
