I am having a problem with my side by side refrigerator. It is a Frigidaire Model #MRS26LGJ and the problem I am having is the refrigerator side doesn't cool constantly. The freezer side is operating fine but the fridge side temp goes from about 35 to almost 60 and this has been happening for the last month. I had a repair man come out and replace the defrost switch and it worked fine for a couple of days but has been acting up ever since. My husband has looked at the coils and they are not frozen up but when the temp reaches its highest there doesn't seem to be any air coming from the vent in the top rear of the fridge side and when the temp is closer to the 35 degree mark I can feel air coming from the vent.
Any and all suggestions welcome
Originally Posted by: wwhitlock  I am having a problem with my side by side refrigerator. It is a Frigidaire Model #MRS26LGJ and the problem I am having is the refrigerator side doesn't cool constantly. The freezer side is operating fine but the fridge side temp goes from about 35 to almost 60 and this has been happening for the last month. I had a repair man come out and replace the defrost switch and it worked fine for a couple of days but has been acting up ever since. My husband has looked at the coils and they are not frozen up but when the temp reaches its highest there doesn't seem to be any air coming from the vent in the top rear of the fridge side and when the temp is closer to the 35 degree mark I can feel air coming from the vent.
Any and all suggestions welcome WW, When it reches the highest temperature in the fresh food, check the freezer back wall for snow or ice, if that occurs, you still have a defrost problem. If there's no snow or ice, I would have to think you've got a bad damper assembly, it sounds like it works backwards. Part number: AP2110308
Good Luck, :) :) :)
