We have a bosch 2400E tankless water heater. When we call for hot water the flame lights, powered exhaust fans starts and blows out flame. The unit does this 3-4 times and gets an EC code. after resetting unit. and call again for hot water unit fires but I block exhaust intake so no air get in ,the heater will light then I slowly let air flow into exhaust fan . Heater will stay lit and work, If we let unit sit overnight same thing will happen again in morning, flame blows out. does any one have any ideas of a problem/ cure. Not to may plumbers in my area even have a clue how to repair. any help would be nice. Thanks
Go to this web site - there is a wealth of information on the water heater http://www.boschhotwater.net/Po...code_troubleshooting.pdf Steve KJR Originally Posted by: kcrtm ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) We have a bosch 2400E tankless water heater. When we call for hot water the flame lights, powered exhaust fans starts and blows out flame. The unit does this 3-4 times and gets an EC code. after resetting unit. and call again for hot water unit fires but I block exhaust intake so no air get in ,the heater will light then I slowly let air flow into exhaust fan . Heater will stay lit and work, If we let unit sit overnight same thing will happen again in morning, flame blows out. does any one have any ideas of a problem/ cure. Not to may plumbers in my area even have a clue how to repair. any help would be nice. Thanks
