otis brown
#1 Posted : Wednesday, November 5, 2008 5:03:59 PM(UTC)
otis brown
hake a claypro wash machine the in the final spin goes og all the time. i took the top apart and the tub seems loose in there but not sure
kayakcrzy
#2 Posted : Thursday, November 6, 2008 4:27:44 AM(UTC)
kayakcrzy
Otis, it is very possible you need to replace the stabalizers. They are the long rod in each corner, that connect to the tub. They wear out, and get loose. Tom ApplianceEducator.com
Out of Balance Samsung WF520ABP/XAA (Washer Repair)
by johnb0529 6/24/2021 10:25:37 AM(UTC)
Roper washer RTW4640YQ1 out of balance (Washer Repair)
by seagypsy 10/3/2020 5:00:03 PM(UTC)
Samsung washer out of balance (Washer Repair)
by Ted L 4/5/2018 4:54:34 PM(UTC)
Washer drum out of balance on spin (Washer Repair)
by breckrider 2/4/2018 4:59:32 PM(UTC)
Out of Balance fault when not wobbling (Washer Repair)
by PCS 1/21/2018 9:39:14 AM(UTC)
washer goes out of balance in the spin cycle (Washer Repair)
by stonecoldsob 2/13/2017 2:07:06 PM(UTC)
Whirlpool top load washer out of balance (Washer Repair)
by gvanzant1 12/3/2016 12:10:33 PM(UTC)
Maytag Bravos UL/out of balance issue (Washer Repair)
by Hmbre97 6/28/2016 6:41:01 AM(UTC)
by Hoglie 6/27/2016 9:38:07 AM(UTC)
Whirlpool Duet wash basket out of balance, making banging noise (Washer Repair)
by relentless85 1/10/2016 1:30:22 PM(UTC)
performa washer comes out of balance very easily in spin cycle (Washer Repair)
by porterbridges 3/22/2015 6:37:48 AM(UTC)
tub out of balance (Washer Repair)
by doormanrick 5/11/2014 11:07:45 AM(UTC)
Front load washer out of balance, all loads (Washer Repair)
by terri.snider 2/3/2014 1:34:30 PM(UTC)
Washer spin cycle out of balance after replacing basket drive (Washer Repair)
by ms031317 11/16/2013 9:39:08 PM(UTC)
Totally Out Of Balance While Spinning (Washer Repair)
by johndqjr 5/16/2013 4:18:20 AM(UTC)
