Due to wall failure(s) causing leaks, I replaced the NUT HUB (WD12X10061) & Connector Pump ASM (WD18X10010). After reassembly the drive motor (WD26X10015) now emits a high-pitch whistle that I would term it to be a "scream." Subsequent disassembly, examination & re-assembly find no observable problems.
HELP!
Check if there are any foreign objects in the pump inlet sump.
