paulej42
#1 Posted : Wednesday, November 5, 2008 11:57:47 AM(UTC)
paulej42
Due to wall failure(s) causing leaks, I replaced the NUT HUB (WD12X10061) & Connector Pump ASM (WD18X10010). After reassembly the drive motor (WD26X10015) now emits a high-pitch whistle that I would term it to be a "scream." Subsequent disassembly, examination & re-assembly find no observable problems.
HELP!
#2 Posted : Thursday, November 6, 2008 11:49:55 AM(UTC)
Check if there are any foreign objects in the pump inlet sump.
